Hello all, I recently tried to set my pump to run at a high speed for vacuuming out the spa, but when I choose a different speed setting on the Jandy PDA, it prompts me to change the RPMs if I choose to. Whether I change from the default or not, the PDA indicates a change (x moves from pool to new mode), but after a second, the x moves back to the pool seeing, and the pump never shows or speeds up. The pump is running fine, just only at a single speed. Any idea what would cause this. Thanks in advance.
Chad
Chad
