- Apr 21, 2021
- 122
- Plaster
- Jandy Aquapure 1400
My user manual says to maintain salt level between 3.0 and 3.5gpl. The display on the unit is showing as 3.9gpl and app shows the same 3900 PPM.
Leslie's says I have 2950 ppm.
Taylor K-1766 test I did says 3000ppm.
Salt test strip says 3200ppm.
They all seems to be in the same ballpark but the salt cell is showing higher. Jandy claims damage if salt is too high or low. Pool is low due to evaporation so I want to add some water and more salt. I'm afraid if I add more salt to be more in the middle of the recommended level (so if water evaporates it's at the high end and if it rains and the water level is too high it will be at the low end) then the cell will think the level is too high and shut off.
How does one stay within the recommended range without the inaccurate reading on the cell thinking's it's too high?
Cell is one month old.
