Jandy Aquapure 1400 - No Flow
farleyville
38
Dacula, Ga
Jandy Aquapure 1400
Chlorine test began to come back zero, so I checked the jandy and the saltwater generator is showinf "no flow".
I've checked filter pressure it is normal, backwashed, cleaned everything, and took out the salt cell and inspected for buildup which there was none, and reinstalled. The temperature / salinity / flow switch looked bright silver and clean.
Any advice on my next step? The unit was installed and turned on in August of 21. So not quite 2 years old.
Do I just need to buy a new sensor? Or is there anything I can do before that step? I have power cycled, hit the reset button on the control panel.
Attached are photos of my equipment pad. I am currently in a SLAM.20230522_192907.jpg
