I have a pool/spa that is controlled by a Jandy Aqualink RS, recently the pool started running continuously not adhering to the set schedule. The inside panel has power but not working when attempting to turn off the pump. I also noticed that at the outside control panel, when put in to service mode it does not stop the system either. After review of previous threads I checked to see if I heard the clicking sound when switching on the filter pump at the box while in service mode and I did here the relay. Cleaner and air-blower works when selecting. Any ideas on what it could be, bad board, loose wire or bad circuit somewhere?
Sean
Sean
