- Jul 18, 2022
- 1
- Vinyl
- Pentair Intellichlor IC-40
I have a Jandy 2 way 4724 valve that has leaked around valve cover since installation. It’s a new valve that I just installed. I installed a 4717 and 7305 at the same time with no issues. I’ve taken apart checked oring and even replaced oring with a new one with no luck. I’ve lubricated the oring with magic lube also every time. I’ve tried tightening the cover evenly in a sequential pattern with no luck.
There’s no cracks or damage to the sealing surfaces but it still leaks.
Leak is 100% not coming from the stem.
Any ideas? I’ve emailed Jandy support with no response.
