Jandy - 4 wire cable part number?
jesse-99
724
Illinois
Jandy Aquapure 1400
I bought a 2nd Jandy Multiplex board (I need the additional RS-485 ports) here: https://www.amazon.com/Zodiac-6584-Multiplex-Replacement-AquaLink/dp/B008E6ST5K
I'm assuming it doesn't come with the actual cable that is needed to connect that multiplex board to one of my two RS-485 interfaces on my main Jandy control board. Does anyone know the part # for that actual 4 pin cable itself so I can try and buy one?
Thanks for the help.
Man I'm sorry you had to pay that. That board is just the four connectors wired in parallel. It probably cost five bucks to manufacture. Jandy is out of control.
We could cobble one up with 4 of these and a PC board for a few bucks more.
If you have the Jandy antenna, then I have just cut a piece from that. I think it is 12 ft long and I had it wrapped in the low voltage side. I just disconnected it from the red connector, cut the length I needed and then reconnected it.
Reactions: jesse-99
