- Nov 27, 2019
- 28
- Plaster
- Pentair Intellichlor IC-30
Hey guys. I’m hooking up my jandy jxi260p to a home brew automation and I have a question about the 2 wire remote. What exactly is the signal to switch on and off the heater? I see 24VAC all over the internet but I let some smoke out of the heater when I gave the pool and common terminals 24VAC. It still works but I’m afraid I fried the remote circuit of the Jandy. I’ve read the jandy manual, went through the mento to select TSAT, and even the board says 24VAC loop next to the remote terminal.
Other than this minor hiccup, this set up is pretty cool, I’ll share it onice it’s all up and running. Big props to to neilroeth on Instructables. He made it so easy, even a caveman can do it. Here it is if interested.
www.instructables.com
Replace Your Pool and Spa Controller With Raspberry Pi, Arduino, Node Red
Replace Your Pool and Spa Controller With Raspberry Pi, Arduino, Node Red: In this Instructable I will describe how to build a pool and spa controller that controls a pump motor, multiple electric valve actuators, lights, a cleaner, air blower, and heater. It also measures the water and air...
