- Aug 22, 2017
- 2,626
- Plaster
- Hayward Aqua Rite (T-15)
So now that I am building my automation system, I figure I need a Stenner pump to dispense acid. I figure 10gpd should be enough or should I go for the 22gpd? Is there a good place that sells the whole kit? Other than the pump and the tank and tubing, what type of injection attachment or check valve should I get to put it in the T?
Also I am in a bit of quandary on where to put the T for the injection site. The only place that I see that I have room is the vertical pipe from the heater return. I am not thrilled about putting it there since it is close to the heater but I do have a check valve or I can run water through the heater when I need to dispense acid. Looking for some good advice here
