Just an FYI, your sand can go a LONG time without ever needing to be changed. Consider it a "permanent" item. If the pool store tells you it has to be changed, just shake your head and ignore them.
fishcrazy said:I got a TFT test kit. Just replenished the chemicals. I did retest the water. FC-18, CC=4, CYA=52 and ph=18. So something is happening now. Still looks the same though.
fishcrazy said:UnderWaterVanya that is correct
Is the psi going up? Are you having to add chlorine each morning (when you test) to bring it back to 22ppm?It doesnt seem to be filtering anything.
Replace that guage asap! You need to know when to backflush. It is hard on the pump to let the flow go close to zero. We recommend backwashing when the pressure goes up 25% from clean pressure. You have no way of knowing when this is, and from the sounds of it, your filter is filtering out a lot of junk.fishcrazy said:The psi is rising but not so dramatically. It is hard to tell due to the fact the guage is stuck on the low side at 30 psi. So I am not sure exactly what the pressure is.
