Hi. I am new at pool ownership and we are having a problem with spa draining when we turn on our hot tub. Our hot tub is not a free-standing unit and is a part of the pool.
Our pool appears to have two main modes. Pool mode is when the pool is on and the pump is circulating water. When the pool is in pool mode, water comes from the spa and it overflows over the edges of the spa into the pool.
When we switch the pool into spa mode, the water is supposed to drop just slightly so that the warm water from the spa does not overflow into the cooler water of the pool. The jets are supposed to start spinning too.
The issue we are having is when we switch the pool from pool mode to spa mode, the water in the spa completely drains. We cannot seem to figure out how the actuator values are supposed to be positioned or where the blue valves on the tube should be positioned. Can anyone offer any suggestions?
Is possible the blue valves are in the wrong position?
