Hello all. I had posted earlier about how both of my valves on the suction side (1x skimmer, 1x for the two bottom drains) were going bad and needing replacement. Well today I tried to take that project on and I have a weird issue that I had not forseen. Once I cut the two valves off, water is pumping out of both pipes from the pool. The pump area that I cut these out of is well above water level. I tried to hook a shop vac up to the skimmer line and I blew it out but as soon as I stop blowing water comes right back up through it. Any suggestions? I can plug off the skimmer line from the skimmer fairly easily to get that one done but the two bottom drains would be a problem.
