- Apr 11, 2023
- 64
- Plaster
- Hayward Aqua Rite (T-15)
Hi,
I am having a serious problem. I closed my pool but I keep my spa open all year. I have it covered with an insulated cover. I came to test the water and had some odd things happen. First. I tested the pH and it was 8.2 (very pink) so I added enough muriatic acid to achieve 7.6 per Pool Math App. Next, I tried to test for chlorine but can’t seem to get an accurate measurement. The sample liver clears after a couple hundred drops but it hasn’t been consistent because i had it change for me with a just a few drops so I can’t make sense of it. So I though maybe, the pH was an issue so I tried to retest it but now it becomes purple so I don’t know what the actual measurement are. When I did get the chlorine drop test to clear and tested for CC it was become very dirty dark brown.
This started yesterday and now today I came to look at the spa and the water is clear by there is foaming bubbles on the surface of the water. I had my SWG turned on but turned it off in case the chlorine is really too high.
I bought the TF-Pro Salt test kit in 3/2024.
I feel stuck and lost because I am not trusting my testing at the moment. I didn’t try to test the rest because of the unreliability of the current issue. I want to test CYA but waiting on more reagents.
Any ideas or insight would be very much appreciated!
