ISO bead receivers
amodali
5
Nesconset, NY
Hello, we are working to replace the liner in our pool. A technician began to do the replacement but stopped the work and asked us to find new bead receivers. He emphasized the size of the gap on the part that hangs over the pool wall. It doesn't seem to be standard size. See photos attached. Where can I find these?
The pool is 21 feet round. We need 66 feet of the receiver track.
Do you know what brand of pool you have? It looks like you may have one of the brands that uses interlocking panels instead of a continuous roll of sheet metal.
Good places to look are Inyo pools, they have a visual catalogue of pools to identify brands. Teddy Bear pools also sells a lot of above ground pool parts and may be able to identify your pool by photos.
If you know the brand then search either of those two sites. They will probably have the parts you need.
Reactions: Mdragger88
Nobody shows dimensions for these, so it’s hard to tell how yours is different. Is it that the part that goes on the wall has a larger gap because the wall has the ridges that make it thicker? Teddy bear Pools makes some that are thicker if that is the case.
