Welcome to the fourm!
Looks good to me. Is that the only test kit you have?
We recommend a TF-100 (link below in my signature) or the Taylor K-2006C. Both are very reliable and do all the testing needed for residential pool care. Check them out and see which one you might be able to order online and have shipped to your location. Good luck!Is there a better tool that I can use?
Yes that's the only test kit tool that I have. Is there a better tool that I can use?
pH is easier to test if you hold the block up to a light background. I have a white plastic chair across the table from me when I'm testing that works excellent.
Hi Chris,Hamzah,
Welcome to TFP! I see you list Thailand and Los Angeles as your location. Where is your pool? If your pool is in Thailand maybe you could ship the necessary kit to Thailand? I lived in Jakarta for over 4 years and found ways to get the materials needed, not usually from the normal channels in the US.
Chris
Hi Chris,
Where to get good test kit in Jakarta?
Thanks
Jonky
