Hi guys! So, I'm in the middle of SLAM and trying to manually vacuum my pool to help the process along, but when I was vacuuming, I heard a loud pop. I noticed there wasn't really any suction and turned it off. When I went to remove the hose from the filter basket, I noticed the basket was pulled under the plastic ring inside. This happened to me a few years ago and what ended up being the issues was the valve (which sits right below the actuator valve) has always been in this position (as seen in the pic below where the cap is darker red) and we never move it. And since everything worked fine we just always figured it was where it should be and left it at that. BUT the year we had the same issues I went out and noticed it was turned in the other direction. It should look like the red handle pic below.
Fast forward this year I THINK they turned the valve into the wrong position (since I'm gaving the same issues) AGAIN but put the handle on wrong so that it looks like it's in the correct position. SMH I took the handle off and took pics of what the valve under it looks like. Can you tell by looking at it if it is indeed in the wrong position? It SHOULD be OPEN like in the pic with (what's left of) the red handle. NOT CLOSED. Which is what I think they did but put the dang handle on in the wrong position. I of course can't tell. Thanks.
