Is there any advantage to a heater bypass?
Apr 25, 2017
222
Greensboro, NC
I'll make this quick: my pool has a heater but it (thankfully) doesn't run all the time.
Would there be any advantage to bypassing the heater in the plumbing so that water isn't running through it unless it is being used? Or is it not worth the effort?
edit: Posted in this forum since I'm considering this a plumbing question.
Keep in mind that newer model heaters (depends on the brand) already bypass most of the water flowing into the header block straight out again. I don't know the percentage of how much water flows through the heat exchanger, but it's not a huge amount. Therefore, the head loss differences may not be much.
Now, from the standpoint of water chemistry, sometimes bypassing a heater can be useful.
