I replaced my previous simple cell with a new simple cell two years ago. SimpleCell I think it is on the fritz again as I'm testing at around 3300 PPM for NaCl but the sensor is much lower. Here are my readings:
+27.23 V
+3.43 A
80 deg F
1300 PPM
-26.27 V
-5.20 A
80 deg F
2300 PPM
I sprayed it out with the hose and it improved some. I then used a 4:1 water - muriatic acid mix for 5 minutes which may have improved it slightly.
Is this indicative of a dying/faulty cell?
If I need to replace it again, does anyone have a replacement recommendation? I'd rather not spend the $1500+ for the Hayward T-15.
Thank you in advance.
+27.23 V
+3.43 A
80 deg F
1300 PPM
-26.27 V
-5.20 A
80 deg F
2300 PPM
