Alright you guys gave me lots of homework and I did quite a bit of it this weekend:
1) Cleaned the filter again (it has only been 3 weeks, it didn't look very dirty ... so I didn't expect much improvement)
2) Tried the backflushing with the garden hose. Our garden hose has quite low pressure (3 gpm) but I stuck it in the suction pipes anyway and with a cloth made sure the water would go into the pipe and not the pump basket. I think water made it back to the pool but I didn't see any dirt or anything come out
Here are the results after 1) and 2) with all the valves in pool mode position (remember the numbers in my first post were with the suction and return valves set to 80 % pool with 20 % spa)
RPM | Watt | GPM | PSI Filter | PSI Pump |
1000 | 58 | 4 | 3 | 3 |
1200 | 90 | 9 | 4 | 4 |
1400 | 149 | 16 | 5 | 6 |
1600 | 238 | 25 | 7 | 8 |
1800 | 354 | 34 | 9 | 10 |
2000 | 501 | 42 | 10 | 12 |
2500 | 985 | 58 | 14 | 19 |
3000 | 1700 | 72 | 20 | 27 |
3450 | 2560 | 83 | 26 | 35 |
3) I next removed the eyeballs to see what would happen. That led an increase in GPM and a drop in PSI.
1600 | 247 | 28 | 6 | 8 |
2000 | 514 | 45 | 9 | 12 |
2500 | 1016 | 62 | 13 | 18 |
3450 | 2620 | 88 | 22 | 34 |
4) And as a last step, with the eyeballs still removed I tested out different valve positions at full 3450 rpm pump speed.
I set the Return to middle where it has the best flow and then tested different positions on the three way valve on the Suction side:
| Suction Valve Position | | |
| Pool | Middle | Spa |
GPM | 88 | 90 | 87 |
PSI Pump | 34 | 34 | 34 |
Then I kept the suction valve in the middle position and changed the return valve position:
| Return Valve Position | | |
GPM | 83 | 90 | 75 |
PSI Filter | 27 | 22 | 30 |
PSI Pump | 35 | 34 | 36 |
After 2 hours of cleaning and testing different things, it looks like I gathered a lot of information but have not really made any progress in improving the GPM flow to what you guys consider typical. Just to mention the distance again to make sure there is no miscommunication on this, the closest corner of the pool is approx. 40 ft from the pump, the furthest return from the pump is approx 90 ft from the pump. The spa is approximately 75 ft from the pump.
Any more ideas on what I should try?
