Financee last used pool two days ago, when she and friend went into spa. She totally knows how to operate the Jandy valves, and spa worked fine, and she put it back into pool mode.
Noticed today that pool had a lot of debris on surface, like the Skim A Round had not worked. Pump won't create enough suction. Pump basket is warped, it looks like it overheated. Tried filling pipes a best as possible, motor runs, but pump hardly works, it creates a tiny bit of pressure in filter, it will bleed just a bit, but no water comes out like normal. Also, noticed both unions that connect pump were not tight for some reason.
Perhaps impeller broke?
1. I have wanted to buy a Intelliflo VS pump 011018, but Amazon kept raising price to $945 plus tax the last month or so. May just find it at another pool store.
2. Meanwhile I have an extra (working when I last removed it) 1 hp pump at my house. So I may bring that over, and try that until I can get new pump delivered.
Thoughts?
Thanks in advance,
Jeff
Thoughts?
Thanks in advance,
Jeff
