Mas,
an AG pool relies on the tensile strength of the liner to resist tearing, when supported (to limit stretch of the liner) by the plastic or steel walls and the pvc rail support system. Some AG pools forgo even that and use a tougher material to contain the water with a reinforcing ring of inflated *even tougher* material at the top.
what the OP was detailing was essentially a rigid (and relatively brittle in relation to a liner) gunite coating over a block and rebar/concrete substrate. The concern in this case is the fracture of the substrate translating through to the waterproofing plaster coat which is not flexible in the same way as a liner (and so not forgiving). I agree that ANY failure in those modes for a rigid pool shell can be catastrophic, as the resulting water flow can undermine and destroy the surrounding area.
So the question is not so much one of catastrophic failure in normal usage, but all of the "special" cases that can occur during the lifetime of the pool... drainage (the inside of the pool wall unsupported), excavation on the outside of the pool for repairs or a project, or the construction of additional structures in close proximity of the pool exerting unplanned-for stresses on the pool wall, even tree root growth exerting tremendous pressures on pool shell. These are the modes a failure would likely occur in. The static stresses of just being a pool are relatively easy to deal with, and that is evident in the relatively inexpensive construction techniques and materials used on "seasonal" above ground pools, which in normal use can last many years!
The real rub here is a question of local economics (which design is cheaper) and owner "gut" (which design am I more comfortable with) which is what we all seem to be debating about.
Me, its pretty obvious which choice I made (gunite reinforced with rebar), but I recognize that other designs are workable, and in some circumstances may be more economical, or just preferred because of availability of materials, skilled labor or some other factor.
I considered steel reinforced concrete filled block for the pool shell, but decided against it for reasons not mentioned at all in this debate. I was worried about the time it would take me to construct the shell, and whether I could keep the structure intact during construction that would take a long time since I would be doing it myself. Since I could afford it, and was building the pool myself for personal pleasure and satisfaction at doing so rather than economic reasons, I chose to take the shortcut of having the shell shot in a monolithic fashion (an NOT SOON ENOUGH FOR ME!!!!) :blah: :blah:
