Opened the pool a couple weeks ago and got everything cleaned and was is the process of balancing the water....
My motor was starting to make a fair amount of noise so I ordered bearing for a rebuild. The pump has not been in service for the last 6 days. Here are my test results right before started rebuilding the motor.
April 20th FC 7, CC 0.5, pH 7.2, TA 50, CH 250, Salt 3400, CYA 30 Temp 68, all of these from the TF Testing kit.
Last night I place the pump back in service.... set the filtering and the salt reading on the display was 3500.
I checked the Aquarite display the is was reading 900. Went through the salt reset and then the number was reading 200...
The cell is 6 years old, I removed and inspected the plates...all looked clean.
LED that are lite are Power, Check Salt, Inspect Salt.
Any Thoughts???
Thanks Dave
Any Thoughts???
Thanks Dave
