I backwash when the pressure rises enough - I’m afraid to do it too often, as I hear the filter works better if there’s some dirt in the sand.Have you backwashed your sand filter? When fighting algae that is needed to clear the sand filter.
Alternatively you can vacuum to waste if that is feasible.
Do you have a hairnet, like they may use in a kitchen. In USA, we can buy a 100 for like $10 on Amazon. So easy to install on basket and then discard. Not sure what you have access to.
The nylon stocking went on the hose last night and caught a lot, so I’m leaving it on to see, if it helps clearing a bit more up
