Photo attached is plumbing connecting solar panels on the roof.
The pipe to the right (closer to the while box of IC60 chlorinator) leads water upward to the roof, and the pipe to the right (where the check valve is located) is water coming down from the roof.
The check valve is installed at the upper side to the clear viewing cover. It opens downward.
Should this check valve have been installed to the pipe on the right side instead, and sits the the lower side of the clear viewing cover?? That way, it will open upward with pump pressure, and when pump stops it will close and stop water to come back down?
Thanks.
Thanks.
