- May 3, 2007
- 18,074
- Plaster
- Hayward Aqua Rite (T-15)
Think of the pump and motor as two separate machines. An induction motor will always run synchronous to line frequency with slip or around 3450 RPM with a load. Changing the impeller to a smaller one doesn't change this much but it will reduce the load on the motor so the slip may reduce slightly but I wouldn't expect the speed to change by more than a few RPM.
As for the resulting head curve, the wet end alone, including the impeller determines the head curve. So if you decide to go with the impeller of the 3/4 HP pump, that is the head curve that will result. It doesn't matter that you have a higher HP motor on a lower HP impeller. The impeller will dictate the performance of the pump. The motor will just use less power.
