I ran an SWG on my Intex for 4 years and will be doing it again on my new Intex without hesitation. Stayed up year-round. Zero issues. However, like everything, I think there is a little more to do in terms of maintenance when it comes to Intex style pools as they are technically bags of water held up by a supporting exoskeleton. During my routine twice a week checkup/maintenance I also hose the pool down, knocking off any debris, cleaning dirt, etc. I honestly think this does help if not minimally. My water is also whole house filtered and treated making it "soft" vs "hard". Typically, the issue with Intex pools and rust is due to their design. First you have poles that slip into each other that are supporting a bag of water. Because of this design there is a lot more flexing (even more so with the rectangle pools), and this is where the majority of these pools rust as the cheap coatings, they use wear off exposing the metal which is thin walled to begin with. Then you have the areas were the poles slip inside the vinyl, that holds and traps moister. The plastic caps and inserts that hold moister. It's just the nature of the beast.
As for SW the salt level is actually very close to and or less than that of the tears in your eyes. I am not sure how one could say a pool or equipment is not SW capable.
