Hello to all the builders/engineers/DIY'ers out there. After excavation, we began installing rebar. Our neighbors back yard irrigation began seeping through our dirt and has created a small pool of water in the bottom of the deep end. The rebar installation company does not wish to proceed and we have been informed this will be an issue when it comes time for inspection due to mud on the rebar/rusting rebar/etc. We have informed the neighbors who are concerned/helpful. They have turned off their irrigation temporarily to determine that is in fact what is causing the issue. Since their water has been turned off, we have seen slow improvement over the past two weeks of evaporation. We suspect their landscaper broke a pipe or forgot to cap a pipe when their piping was being re-worked for new back yard lawn. I have read that many construction companies use quicklime/hydrated lime to dry dirt and prepare the dirt for long term. My concerns are that after the shotcrete/gunnite is installed, what will the long term effects if water returns under the pool from their irrigation system once its turned back on and we are unable to inspect that area? What are anyone's thoughts on using lime to dry up the effected area? Will the lime effect the bottom of the pool shotcrete/gunnite longterm? Any help or thoughts are greatly appreciated. Truly appreciated - Rich Davis
