Hi guys,
My pool has persistent iron staining. Two seasons ago I drained and acid washed. Last season I did an AA treatment and then drained. Pool was clean all summer and closed clean. I just opened the pool and found iron stains (confirmed by absorbing acid test) again. The iron stains are concentrated in the shallow end and specifically on the area that was below water for the majority of the winter e.g. areas that were above the initial water line when I closed the pool did not suffer staining despite being above the water line by the time I opened. The spa does not have any staining. The water repeatedly tests negative for iron and copper at my local Leslie’s— literally 0.
The plaster is passed it’s useful life and is failing. I believe I have areas where rebar is rusting through. But I would expect tests to show meaningful iron levels in the water and they never do, even in the past.
Picture show the staining as well as results of small AA test on the steps which lifted the stains instantly.
Any ideas as to what’s going on?
Thanks!
Thanks!
