Liner install is complete. Plan is to run the pump with the main drain open and skimmer off (water isn't high enough.) See what the DE filter can pull out.
Checkout my thread on adding DE.Ckk, I just realized your in Kzoo and you're salt water.
While I'm cautiously optimistic that your mechanical filtering will reduce your iron load, I'm not as optimistic that you'll be able to avoid something like Jacks Purple...just that you won't need as much. Pool Chemicals, Hot Tub Chemicals and Supplies | Pool Geek carries it and reaches Mi locations overnight. Fingers crossed that you can just skip it...but just in case
Secondly, in your town, The Water Boy has a 12,000 gallon tanker for $499...decent price for size if you ever find you need to dilute. I have his number somewhere if you ever need it.
Lastly, is that liner floor Seabrook, and who did you get it through? I'm getting ready for a liner change up in GR and can't seem to get that border from my preferred vendor, but can get Seabrook borderless.
I'd get in that pool.![]()
Post vacuum. Very happy with the results. Water testing at 0.2ppm for iron.
Sent from my SM-G920P using Tapatalk
Thanks! I think that's the highest compliment around here. [emoji2]I'd get in that pool.
