Hi All,
Many of you have been helpful this summer as I struggled with iron after 20 years with none. I have figured it is likely due to my town having done renovations on water pipes and the fact that my home is the lowest point in neighborhood. Had professional lab testing and municipal water is fine now at my home.
So, I'm going to change out all the water. Should cost about $300. Less than the sequestrant I have to continually add! LOL.
MY QUESTION - I plan to add ascorbic acid to release all the iron before I pump out all the water. Is there any legit/scientific reason/advantage to add sequestrant after the ascorbic acid? Will the ascorbic acid be enough if I'm dumping within a few hours? Is there some chance that while I'm pumping out water some iron will stick to liner and that sequestrant will prevent this? Want to have all my bases covered on this one!
Jeff
Jeff
