I am not a dad. I am 71 years young and swim 4 to 8 blocks a day in Minnesota lakes but now the lakes are too cold. I bought the Intex 9.10 foot x 7 foot x 29 inch pool and am putting it in my basement. Silly? I dunno? I boxed it in with 2 inch polystyrine for cushion then 3/8 inch plywood. I have a 2 x 4 frame around all that. I slammed in a corner and bolted together on the open sides with the 2 x 4's. Poly is also under the pool as well as bed liner.
I will need a heater. I'm seeing that the heaters fail often. Seeing $200 - $400 might do the trick. Not sure what to get. In the local lakes, I quit swimming when they hit 65 degrees. I can be comfortable at 67 or 68 degrees so my 1000 gallon pool only needs to be that hot. I'm wondering if a 500 gallon heater will be enough? I have a circulation pump that new was $140 or so but Wal Mart was selling it new for around $45. Not sure how to hook all this up but I'll figure it. Local electrician is going to wire the heater into the box so it is all code and correct.
I'm using a bunji cord harness that will allow me to swim forward 3 or 4 feet and it will pull me back. I just want to do 20 minute sessions a couple times a day. I've lost 35 pounds this summer and I eat 80% veggies and fruits. Stir Fry is my friend. Chicken and fresh fish, steak, pork, and burger. No bread or cereal, sugars and empty carbs. Swimming is king.
I will run a dehumidifyer in the room as the furnace is there too. I will use a sump pump to pump the pool out into my yard which is huge and rural. I will put a cover over it when not in use. I will run the dehumidifyer on a timer every 5 hours on / off but may vary that.
Anyone see anything wrong with this? I guess my introduction serves as my questions. Appreciate any suggestions and if I need to move my comment/questions to a different topical catagory, let me know.
