I just installed my pool pump/filter - Intex SX 3000 - and as of right now I am happy with it other than 1 problem. The problem: It's spitting sand into my pool. More sand than I feel should be in the pool after an initial start-up for a new machine though I am by no means an expert as I have minimal experience with filters/pumps.
I have a theory though, and I wanted to run it through here as I am hoping I can get an answer faster than I can through Customer support (2 day estimate on response).
So I have a question:
When I was setting up my filter I noticed that the center pipe hub (#7 in the attached diagram) fit what I feel is pretty loosely into the filter head.
So my question is: How snug should this piece of pvc be where it slides into the actual filter? Should it be somewhat snug or is it typical for the connection to see loose.
-- My definition of loose is: the (2) pieces would not stay together if I were to allow the weight of the center pipe hub + laterals to dangle from the filter head.
I don't see any o-ring requirement on the diagram, so I don't think i'm missing any extra parts, but I do feel that sand could bypass the laterals and go in between the center pipe hub and into the hole at the bottom of the filter head.
Anyway - hopefully what I'm trying to convey is clear. Any/all help is appreciated.
