This is getting a bit annoying lately... I've been through 2 in the last 2 summers, and now this one is (i'm guessing) on it's last leg as well. There is no way these things are meant to only run 4 hrs a day. I run it 12 (the max) and it can barely keep up. In fact... it doesn't... After running for 12 hrs (*during the day* as pool school suggests) and checking chlorine level in the evening, it's usually between 1-2.5... I check it again in the AM and it's the same (maybe a tad lower, but not enough to worry about shocking again). So i then use the calculator and add bleach to bring it to the high end for my CYA which is 80... My PH is about 7.5 - 7.6, and TA is about 100-110... I checked my salt again this AM after adding some a few days ago, and I'm right at 3200 ppm... About an hour ago, I walk out to have a smoke and hear beaping... It's register as low salt... REALLY???? :grrrr:
I seriously don't know what else to do here... My water is, for all intent purposes, perfect... Crystal clear, and looks amazing... but at the very least I shouldn't have to run the SWG at it's max to maintain... and like i said... it's not even doing that... not to mention the "low salt" error now...
Is anyone else having this problem? ugghhh...
