Intex 12x24 above ground with ECO20110 pump/SWG combo. We've had our pool up for about a month now. I've been struggling to keep the chlorine up and am often adding liquid chlorine. I've been running it on FP mode because there is also a heater installed. I keep running the boost mode to try to get it generating more chlorine but doesn't do much. Reading thru manuals last night I think I found that the SWG will only run in the automatic mode (up to 12hrs/day) and if you run in the FP mode (24/7) that is how you run the pump without SWG.
Can someone confirm this? AND IF TRUE
How can I run the pump longer to allow the heater to run when it needs to?
CYA: 70
Salt: 3400
Ph 7.5-7.8
FC...trying to maintain 4-5 but really struggling. Water is clear.
CYA: 70
Salt: 3400
Ph 7.5-7.8
