Hello all!
I'm new here and did some searching before my post, but didn't come across a thread that was my "exact" situation. Hopefully you guys can help me solve my issue as I've been trying to get things running for weeks on my own (UGH!)
So, I've got my filter set up (brand new), followed all the directions (no air in the system, and no leaks - water level consistent. The problem is, when on filter mode, it runs fine for a bit (about 5-10 minutes) then water progressively stops flowing out of the output into the pool. Pressure gauge is always fine in the green, and I've done the backwash and rinse process several times (water is always clear). I read about algae being an issue, but I don't think that is the case because the issue is present with fresh water.
I know the pump itself is working fine because the recirculate mode runs without issue.
Help me!!!! Thanks in advance!
