I did a search for this question/issue but couldn't find any information so here we go...
We recently bought (used) the Intex pool pressure-side cleaner - Model 2800ie - which requires a filter pump with a flow rate between 1,600 - 3,500 gph. Our 1.5hp Hayward pump has a maximum flow rate of 7200 gph. Our pump is way overpowered for the cleaner and the head of the cleaner "flies" around inside the 20' pool instead of running along the bottom as it should. Are there any modifications that can be made to make this cleaner work with my existing pump? Thanks for any suggestions/solutions. [in case you're wondering why i bought a cleaner that doesn't match my pump... i didn't know any of these specs when i made the purchase.]
