I just put up an Intex 18' pool that comes with the Krystal Clear Sand Filter. I *think* it is pulling water and filtering it as I see water go down and into the pump and then out the jet spray but I think this is mostly gravity. I also tried to connect a vacuum to the intake hose to vacuum the pool and there is just no suction.
Moreover, I cannot turn the handle on the 6 way valve. I took the top off of the pump and removed the handle and made sure nothing obvious in there jamming it. But saw nothing.
What else can I do to troubleshoot or am I missing something?
Thanks in advance!
Thanks in advance!
