Yes, it is safe to swim up to the SLAM level for your cya level ( which if your 100 ppm cya is correct would be 25 ppm FC).
You got it. For example 0.1 ppm FC at 0 ppm cya has the same "active" or "disinfecting" chlorine level as 10 ppm FC at 100 ppm cya.PoolFrog said:Is the high CYA keeping the chlorine weaker at that level than it would be if the CYA was lower (normal range)?
Algaecides will kill algae, just not at a fast enough rate for the SLAM process. Proper chlorination does the job whether SLAMing or maintaining.JohnN said:Algaecide does not kill living algae. It only helps prevent an algae bloom from starting. I didn't re-read the whole thread, so I don't remember the whole story. Have you ordered one of the recommended test kits? Where did you get the CYA of 100 from? If you didn't order one of the recommended test kits, do that now. Since you have green spots, you will need to SLAM the pool, which will be impossible without the recommended test kit, and also difficult with a CYA of 100, which could actually be much higher.
