Hi All,
My first Intex 9x18 pool is on the way and based on feedback I've read so far on TFP it's recommended to upgrade the sand filter. In addition, I'd also like to install a salt water system. Is it recommended to buy a separate filter and salt water system, or should I consider getting a combination unit?
The options I'm considering:
1) Intex Krystal Clear Sand Filter Pump for Above Ground Pools, 16-inch, 110-120V with GFCI (~$329) - Pump flow 3k
2) Intex Krystal Clear Saltwater System with E.C.O. (Electrocatalytic Oxidation) for up to 7000-Gallon Above Ground Pools (~$200)
3) Intex 26679EG Krystal Clear 2150 GPH Pump & Saltwater Sand Filter Saltwater System (~$275) - Pump flow 2.6k
Appreciate your feedback!
