Intex 603 pump/filter to a 635t pump
Jun 23, 2017
4
Winston Salem
I need help guys!! I have the intex easy set pool that is 13' by 33 inches and the pump that came with it sucked. I bought the 635T pump (going from 530gph to 1500) and need help. Do I have to buy more parts? I know I do to connect the bigger hoses to the smaller ones..but besides that?? ALL ADVICE is appreciated!!
HI! YEAH on a bigger pump! That should move some water!
There is a search box at the top right of this page. It goes to only TFP posts/threads. See what you can find there. If you can't find it let us know and maybe someone can help.
Kim:kim:
Yes you may need the 1.25" to 1.5" hose adapters. INTEX 1.25" to 1.5" Type B Hose Adapters for Pumps & Saltwater System | Set of 2 https://www.amazon.com/dp/B0036WH9JO/ref=cm_sw_r_cp_apip_wUV4s3J6aS1M1
I have the 12' x 30" Intex and needed them. One attaches to the T on the intake and one will attach to the return line. (Unless you go with the larger return head). I went with the larger return head.(came with the pump). It required slight cutting, but if you go slow it's easy.
I ended up going with the 2500gph pump, so slightly bigger. In my opinion it was worth the extra $10, although I should have just upgrade to a sand filter...
