- Nov 30, 2021
- 8
- Plaster
- Pentair Intellichlor IC-40
Hi, I’m looking for some guidance on addressing the intermittent tripping of my GFCI. I have read through several threads and think I have narrowed down what I need to do to fix this issue, but I’m looking for guidance.
Current setup:
I have a Pentair Easy Touch load center. It’s fed from a 100 amp sub panel that splits into two 50 amp GFCI breakers. One feeding the Easy Touch.
Load center breakers:
15 amp to the Easy Touch controls
20 amp to GFCI outlet on side of load center then feeds three relays for pool lights
20 amp to BBQ Island
4 pole 20 amp breaker feeding Pump Relay #1 and Relay #2. #1 relay is connected to my vs Filter pump, heater and SWG. #2 Relay connects my booster pump.
4 pole 20 amp breaker feeding a vs pump for a waterfall and Relay #4. #4 goes to a single speed pump for 2 Laminars.
20 amp gfci to Relay 3,5 to pool lights.
Issues that need corrected as I see them.
#1 Remove the 50amp GFCI breaker at the sub panel and replace with regular 50amp breaker.
#2 replace all breakers in the Easy Touch with GFCI breakers with same rating.
#3 wire VS filter pump directly to breaker, it should not be attached to the pump relay #1.
#4. Power pump relay #1 from relay #2 to power SWG and heater.
My issue is that I do not have enough room in my load center for all the breakers. Replacing the two 4 pole breakers feeding my 4 pumps with four 2 pole gfci breakers takes up more space. I currently have 2 open slots on the load center, but will need 2 more to accomplish what I’m planning.
I can move the breaker for the BBQ island into the sub panel that feeds easy touch. This frees up 1 space in the Easy Touch.
I was thinking that I could eliminate one of two 20amp breaker that feed the lights and run all from a single breaker. I have 4 pool lights, 1 spa light, 1 small light behind the waterfall and the 2 laminar lights. All lights are Pentair color changing lights. This would free up a second space in the Easy Touch.
Please let me know your thoughts on my plan. I’m open to other ideas on accomplishing the the fix. We’re planning a couple week long trips this summer and don’t want to worry about the breaker tripping and shutting down the system while we’re gone.
Thank You,
Ryan
Current setup:
Thank You,
Ryan
