Split from Electrical shock at pump skimmer basket with Superflo VS new install Zea3
PoolEinstein, did you ever figure out what the issue was? I am having the same exact issue, similar set up without the SPD. Electrical shock intermittently when I touch the water in the pump basket unless I turn off power using the manual switch on the Intermatic box (timer function disabled). No electrical shock in the pool.
