Electrical shock at pump skimmer basket with Superflo VS new install
Background:
Old (1960) 28,000 gal dive pool with big deep end and diving board. 1.5" copper inlet (direct to pump via 90 deg) from skimmer, 1.25" copper plumbing to pool. Plumbing between pump and filiter is 1.5" PVC
Replaced a twenty plus year old Sta-Rite with Franklin 1hp pump motor which was sucking major juice. Its a 115 volt motor hooked up with only hot, neutral and ground (to intermatic timer box only). No bonding wire anywhere.
This setup yielded a workable (wouldn't always prime, loud running) that would not give me an electric shock when touching the water in the pump skimmer basket or anywhere else.
New Setup:
Pentair Superflo VS (342001) replaced old pump and required 1.5" copper to PVC compression adapter (inlet) and 1.25" to 1.5" adapter (outlet).
Same 115v hookup as old pump but incorporated an Intermatic PS3000 Surge Protection Device at timer box tying the two black wires into the hot and the white into the neutral.
This setup yields a good electrical shock upon placing a finger into the pump skimmer basket water. If I stick my finger or hand into the pool skimmer or pool itself, no shock. If I kill the power at the Intermatic Timer (shutting power off to the pump), no shock anywhere.
So my questions:
1) Given that the old pump was not bonded to the pool (unless the copper 90 deg inlet screwed directly into old pump counts as a bond?), why am I now getting shocked where previously i was not?
2) Would the Intermatic PS3000 (and/or the way I wired it) have anything to do with it?
3) Could the new pump be bad/have a short?
4) How can I remedy this or what would be the logical steps to figure this out?
Please go get it immediately inspected by a professional. Others may jump in here, but this sounds like it needs to be addressed by a professional electrician. I would not let anyone swim until you get it checked out.
I agree with getting an electrician unless you are good with diagnosing electrical faults. Chances are you are not or you wouldn't be here. That being said if you do have the necessary skill/ knowledge. I would measure the voltage in the pool and all metal components. Compare these reading with the main breaker in your electrical panel off (to rule out any issues you have caused by recent wiring changes, I would also install a jumper from the copper pipe to the bonding lug on the motor, heater and any other metal pool equipment and test again.
Found the solution to stopping electrical shock at pump: Remove PS3000 SPD from the loop. Question is, why? Had it hooked up in the old Intermatic T101R box (timer function disconnected). Here were my 120v connections that caused the initial issue:
1) White (neutral) incoming to "A" combined with white of PS3000 and neutral to pump.
2) Black (hot) incoming to "1" combined with both black wires of PS3000.
3) Black (load) output to pump connected to "2" of timer.
This uses the old timer as a remote shutoff to pump.
What did I do wrong?
