I have a pair of Intermatic timers regulating my pool pumps. One timer controls my pool pump for the filter, the other controls a booster pump for my Polaris cleaner. The yellow dial on the filter pump (your left in the attached photo with the two dials) no longer works. I can see gears move on the timer motor (in the back of the timer), but the yellow dial with the time markings doesn’t rotate. I have no problem if I pull on the dial and want to reset the time, but once set, the time does not change.
It was thinking I should replace this timer. My questions:
1) What model do I have? I can’t seem to find that information on the timer.
2) What does that thing in the lower right corner of the left timer do? It is not present on the right timer. Will the presence of this thing complicate my replacing the timer?
Thank you in advance for your help
