So when I went to open my pool, I went downstairs and went to make sure the power was on. I noticed that the little on/off triggers were loose and janky looking. I am thinking that the on/off triggers got loose at some point over the winter and bound up the timer dial, possibly stripping the gears on the timer. This is a just guess, but either way, here's the issue....
The timer is not keeping proper time now. It moves, but it ends up being hours behind when I go back and check it later. This sounds like the gears are stripper or something, based on what I've read.
My main question... is it really worth replacing the gear drive if these things are only like 40 bucks on amazon and I can get a new one in 2 days? Unless the gears are like 5 bucks, I assume not.
My OTHER question is.... I hate having to run down to the basement and turn on the pump if it's not during a time that I have it scheduled for. Are there any wifi enabled timers I could upgrade to where I could turn the pump on from my phone or something? Maybe I'm being lazy and asking for too much here...
Thanks!
Thanks!
