Ok, changing motor and adding P1353ME & Stenner here's my questions.
As I understand it Circuit 1 & 2 will be used to supply 2 speed motor for hi/low speed and circuit 3 for stenner pump, programming modes I'm thinking mode #2 so the Stenner can come on independent considered mode #4 but as I understand mode 4 the stenner would come on only after the motor has been on HI for at least 30 seconds , I like the idea of the stenner not being able to inject unless the motor is on however I'd rather not have the pool pump on hi everytime I inject, anyway to set this up to have the Stenner come on when motor is on low? Should I set to mode #2
What are others doing with 2 speed motors and stenners, mode? How many times can I set the #3 circuit to come on and off per 24hr period? As I read in manual 3 times per day sound right? Should I be injecting when in HI speed or will LOW be ok?
