Intellivalve multiple stop points
cactus_LV
133
Las Vegas
Hi,
I know that there are many threads about Intellivalve and how great they are LOL but I couldn‘t find anything about setting multiple stop points with the IntelliCenter. Is that something which finally got implemented? I have multiple valves and would like to assign one to more than one circuit but that doesn’t seem possible.
Also I have a bubbler (it’s on a 3 way valve with the returns) and I would love the option to have 3 programs for it: max (only open bubbler), average (open both returns and bubbler), off (only open returns). How would I implement that with an Intellivalve and IntelliCenter?
Thanks!
Vary the rpm of the pump by setting up Feature Circuits and putting an rpm as appropriate for each one. But the return will be all bubbler or all return.
Are their any plans to implement that at some point?
If the default position for the valve is bubbler off and I want to feature circuits with the bubbler on: 1) low flow and 2) max flow how would I achieve that? I can only assign the valve to open the bubbler to one circuits is my understanding.
You would have to ask Pentair.
Good question. I have not tried it. You would use the same valve just have separate Feature Circuits with different pump speeds tied to it. If you engaged multiple circuits at the same time, the one with the highest rpm would win.
you could do this as a circuit group . your feature circuit would activate the bubbler on the standard low pump speed (assuming vsp)
Your circuit group would include the bubbler feature plus a pump high feature
most recent info was from @MyAZPool who has had contact with pentair
