just wanted to check to see if this diagram is correct. i was under the impression that you couldn't flow straight across a 3-way valve and isolate the inlet port. pentair shows this being done in this diagram for their heaters. is this correct? can you flow across the valve this way and isolate the port that i have hi-lighted yellow?
