- Apr 29, 2018
- 15
- Plaster
- Pentair Intellichlor IC-30
I’m retrofitting a pool system with 3 bodies of water, two pumps, five 2-Way valves.
feature rich to say the least.
using : IntelliTouch i7+3 including 3 valve module #520285
I'm learning on workbench prior to actual install at clients home , and I'm glad i did.
10 circuits > “pool” , “spa” , “waterfall” , “stream”, “cool down”,AUX1, AUX2 ,AUX3 ,AUX4 ,AUX5
If I want positive control of each valve it appears I need 5 AUX(valve assigned) features.
then when setting up a macro I have ability to turn each on/off as needed.
When setting up macros there are only 8 button choices, are the other two vacant buttons the “baked in” Pool & Spa features?
I relate to the valves as ABCDE
A [ filter pump suction] B [filter pump return]
filter pump is energized with AUX1 relay.
When assigning a valve to an AUX output is the physical relay necessary ?
Can the assigned relay be utilized for other load or is it married to valve always working simultaneously ?
I perceive a conflict in the relationship between “Pool” and “Spa” (main page buttons) (baked in "Circuit" )
and valve assignments with other features.
example;
POOL button > turns on AUX1 (filter pump) with no valve action . this is a “baked in” function without otherwise required valve assignment.
SPA button > spa is jetting = AUX1 ON (pump) , valve A ON valve B ON this is a “baked in” function without otherwise required valve assignment.
transition to macro
Waterfall circuit AUX1 ON (pump) , AUX2 ON (pump) , AUX3 ON (valve assigned) > then valve A OFF ( filter pump suction)
how do macros fit in relation to “baked in” functionality
what am I missing other than expanding to a i10 or other expansion module ?
example;
transition to macro
