IntelliTouch chang pump speed if heat is on?
jtech1
0
407
I have my Intellitouch set up with VS pump and have pump set at 60 gpm so there is enough flow for when the heat pump is in use. The 60 gpm flow is set to the Pool circuit and is used anytime pool is on. Is there nay way to set two speeds on the VS pump (I know I can do this) and have it choose which speed to use based on whether the heat is turned on or off? I can't seem to figure out how to do it... if it is even possible. I only want 3 gpm if heat is not on.
Yes, there's a pump state of something like "heater active". In your pump settings you choose that and set the speed. When the heater turns on, the pump speeds up automatically....
From the ICP...
MENU/SETUP/EQUIP/INTELLIFLO/Select pump you wish to assign speed to/ASSIGN CUSTOM SPEEDS OR FLOWS/Select which function you wish to assign a speed to.
If you don't see it, you can choose a window with a "NONE" label and begin to scroll through it till you find what you are looking for (pool heat?). Just be careful not to make two labels the same, otherwise, the system will only obey the one with the higher pump speed.
Then dial in your speed or GPM (up or down buttons). Once you have done this, go back to the "pool" speed and turn it down for your energy savings.
And Don't forget to hit "SAVE" before exiting.
