Major equipment delays are making me reconsider options. I have a pool spa combo under construction that will use a pentair vs pump with 4 separate relays of lights, main pool, spa, 5 globrites as accent lights and 2 magic bowl lights. The magic bowls will be plumbed with a second VS pump that will feed the bowls and the sun shelf deck jet bubblers so they can be used at the same time as the spa. Independent control is key and I want to make sure if I opt for an available easytouch 8 the system can handle the two pumps and all the other equipment. Happy to provide any other details if needed.
